Fuse for a fan
pamopfl
Hi,
On my 2008 GS/SE5, When going thru my fuse box I noticed there was a spot open. The owners manual says it is for a fan 15a. Is this for an after-market fan? Or some other fan? Should I put a fuse in it?
Thanks!
Hi,
Thanks!
Slot 10 in the front fuse box is for the radiator cooling fan. That fuse is a must or the cooling fan will not work and the engine will overheat under some conditions. I have a hard time understanding how you could drive it this way.
Fuse it..!!
If it is for your fan you need it, if it is an empty slot putting one in won't hurt or cost much. If you have not overheated or run really hot and hear or feel your fan come on, then it's not your fan fuse. Otherwise it is..be safe put one in...:thumbup:
