Fuse box
nightshift357
Hello to all,you name is Pete aka night shift. I have a 2015 RT limited. Trying to find the fuse box. The 12 volt plug in the trunk is not working . I assume it's a bad fuse. Any advice would be appreciated.
Sent from my SM-G925V using Tapatalk
The 2 fuse boxes are located behind the front trunk. They are accessed through 2 access panels located in the front trunk. In you owners manual it describes how to access them starting on page 151.
I think it is switched unless you move a fuse 1 position. Try turning the key on and see if it works. If it does them you need to move the fuse
Sent from my VS990 using Tapatalk
not to be a smart ass
Not to be a smart ass but you have to unzip the liner in the frunk to get to fuse boxes.
It should be on the F6 fuse which is switched by the key. If you want it hot all the time, move the fuse from F6 to F7.
