Greetings
I've scoured the forum. Really. I have. Many have asked the same or similar question. The answers don't seem to address my situation. So I'm being redundant in hope of getting a simple, clear, solution.
First, my bike is a 2015 ST Limited. There's no trunk, just the frunk.
Second, I'm wiring in heated gear and a voltmeter/USB charger (in the switch panel). I have wired a relay feeding a fuse block and routed the wires from outside the frunk to their appropriate location, tested everything and all's well.
The problem? I STILL haven't found a wire near the frunk that is hot when the ignition is on to trigger the relay.
I have a factory manual and I've gone cross-eyed trying to follow wires. What I need is a wire near the front left of the bike that I can tap. Specific location and color would be the source of much delight. ("Use the LED wire on the driving light circuit" might well work, but not if I'm clueless as to where that wire is. And, as you know by now, I'm clueless.) Anyone have a clue or three to offer?
I'm aware of the danger of making CanBus sit up and take notice. The current draw is almost nil, since it's just telling the relay to wake up. Anyway, if you've read this far, you know what I'm after. If you're still awake after reading this saga (I do tend to run on a bit...) I'm grateful for any specific direction you might give, remembering it's not an RT or an F3 and it's not yesterday's model.
Thanks, all.
Forgot to mention that the 12 volt accessory wiring on the frunk is not attached/working. Previous owner didn't have the dealer install that, I guess. I really don't want to remove the frunk to get to that accessory plug/wire/whatever it is.
Thanks, all.
