Spyder2780
Hi all....I need to find a 12v keyed ignition source to power my amp. I dont want to positap anything as I would like to be able to return everything as it was stock if I were to remove it from the vehicle and I dont want to draw more amps off a current circuit just in case the amp malfunctions I dont want to lose any other OEM function. Iwas looking at the fuse box and it looks like there is a 3amp switched accessory. Does anyone kno what that is used for or is it open for use? What about the wires coming out the back, where do they lead to? how do i connect to a fuse? Also, what about the optional foglights circuit. I do not have foglights so is this open as well? I could also get a secondary box for the accessories but how do i tie that into the fuse panel? I could just put the wire under the fuse but i would hav to leave the cover off and I notied that the OEM box is sealed? Any help is appreciated...Thanks!!
