I am considering removing the nozzle restrictor plate from the filler neck. Has anyone done this? If so, were you able to do it with a heavy duty aviation snips? I am very hesitant to do it with a saw or dremel. Fumes and shavings, donchakno.......
Okay... I'll be the first to ask.... WHY?
... So you can put 5 gallons in your Spyder three minutes faster?
... So you can siphon fuel from other places with larger nozzles?
... To increase capacity by .0003 gallons?
... Just because?
Because the fuel spits up through the two vent holes and the droplets splatter onto the paint. Then I need to grab a towel, which may or may not be available, to quickly wipe those spots off. Thought is, make the two small vents into one large vent and eliminate the spitting fuel.
This is where some people got into problems on earlier spyders with getting fuel into their vapor canisters. Topping off any modern vehicle is not recommended. I carry a 1 gallon can from REDA just for these times.This pic is not in my operators manual. It simply states: 5. Fill the tank until the fuel nozzle automatically clicks and shuts off.
NOTE: Do not try to top off the fuel tank. Leave some room for the fuel to expand ........ .
I can generall get about 1/2 gallon into the tank after the pump shuts off. That is equal to about 15 additional miles before a fuel stop. And since all fuel stations have been removed from the Blue RidGE Parkway, that 15 miles could get critical. IMHO.
Okay... makes sense to me now. I don't have that problem on my RT, nor have I experienced it on the other three Spyders we have owned. I never trigger the pump fully and I never use the automatic shut off so maybe that is why. I know that in some states we have traveled in the nozzles have these terrible rubber thingys on them that make it difficult to access the filler neck. Here in Georgia we have reasonably thin nozzles that allow air to escape when the fuel is going in so there is no splash back out the vent holes.
Using a Dremel tool will cause sparks which ignite gasoline. I used tinsnips and an aluminum pry bar when I removed the baffle like obstructions in the filler neck when I installed the self closing/sealing gas cap and the gas door in the seat. Now I can refuel without getting off the bike
https://www.kleenwheels.com/vmchk/Permacap/Permacap-PC24001![]()
Andy
