Jeriatric
Thinks out loud
My fuel line leaks (yes plural).
As most rubber will. The fuel lines have shriveled due to under tupperware heat. Causing several oetiker clamps to become loose and cause leaking. The 'O' rings in the stab fittings (quick releases) have also shriveled causing them to become loose, and thus leak.
A heads up for all who do a lot of rideing in high heat, low humidity climates and/or those who perform DIY maintenance.
