Frunk
FYI
Old post from me, just thought I would throw this in.
So last week my ONLY Spyder key got lost. I called the dealer and their first suggestion was to call a locksmith so I called six and none could help. I then called the dealer again and they said I have to replace the ignition at $1000 cost. I started to question why I only got one key with the purchase of my brand new Spyder from them and the tone changed dramatically. I was was told to get it to the dealer and they would get me a new key. It is still at the dealer and I have no idea yet how they plan to fix this. Will update when final resolution occurs. Oh and by the way UHAULS 6' x 12' open trailer only has a 5' opening so it is plenty big for the bike but getting it on (sideways imight add) I scraped the fenders.
:banghead: :yikes: :pray:
What I did find in this ordeal so far is a WAY too easy method of opening the trunk and seat without a key. If you turn the handlebars hard right there is a cable with a small white marking coming out of the ignition housing. The is enough slack in mine to create a small loop. I just grabbed hold pulled a a little (do not need to yank) and the Frunk popped open (I have a frunk spring). I turned the handle bar the other way and there was a solid black cable same place on the other side. Gave that a pull and sure enough the seat came open. I am sure this is universal for all RS models not sure about RT or ST models.
PUSH YOUR KEY IN BEFORE TURNING IGN OR RELEASING FRUNK/SEAT
I had a similar issue with the frunk being "tight" after my ignition was replaced. I took back to dealer and they lubricated the latch, but still is tighter than I would prefer. Ditto on Mikes suggestion to have someone put gentle pressure on lid while turning the key, and be very careful as noted about snapping the key..
We have 2 2009 Spyder's 990RS SM5
From day 2
we always insert the Key 7/8ths of the way in
then GENTLY-TAP the Key the rest of the way In
then turn Key for Ign. - frunk & seat releases
key should turn smoothly
this has been a Issue with Can-Ams since 2008
there Somewhere in the Annals of Old Post's - are previous posts
......................................................... tom n carol
Thanks folks, I got it opened. Too much pressure on the latch. Just pushed hard on the Frunk while I turned the key. Thanks for all the helpful info.:bowdown::bowdown::bowdown: Ride safe, and...
Ride in comfort,
John
