Quite aside from adding a spring or doing any adjustments - adjustments that can be made to the latch, latch pin, or the cable length itself (take the covers between the frunk top & headlight base off, you'll be able to see the latch & potential adjustments more clearly that way...
) you might want to check that the rubber seal/gasket around the top of the frunk lip is seated firmly & properly in place - almost all Spyder owners eventually discover that if that's not on properly, it can cause difficulties with the frunk opening! So can over-filling the frunk or leaving something dangling out over that gasket, cos if the frunk's too full &/or you've left/ got anything crossing the gasket, it'll be putting the latch under too much tension, so it'll be harder to open - something which is usually usually alleviated by gently pressing
DOWN on the lid above the latch while turning the key in order to get it to Un-latch....
hyea:
Many of us have also added that 'emergency opener' cable RICZ mentioned (& as also mentioned, some then use it as the 'normal frunk opener'
) which is simply a cable running from the latch to somewhere out the side/in the wheel well, initially in case the key operated cable gets dislodged/breaks or if something else causes the frunk to jam shut; but I suspect most of us have found that we will still
occasionally need to press DOWN on the lid (to reduce the tension on the latch) while turning the key in order to get the lid to open easily/without forcing the key too much. Forcibly pulling the lid
UP to open it is not a great idea - it stresses the latch, jamming it shut even harder over time; eventually it can cause the latch to 'bend up' a little, ultimately making the latch even more difficult if not impossible to open/release; and it can even break the latch/latch mounts!! :lecturef_smilie:
So before getting too fixated on making adjustments to anything &/or fitting that 'Emergency Release' (altho you should do the E/release thing in due course!
) just check that rubber gasket thingy; make sure you don't over-fill the frunk or leave a pig-tail cable or something hanging over that gasket when you shut it; and if it's not opening easily, try gently pressing
DOWN on the lid above the latch in order to lessen the locking tension & make it easier to open! :thumbup:
Good Luck! :cheers:
