Have a 2013 RT limited and the trunk will not unlock. Haven't a clue was working great then nothing. Any ideas?
The microswitch in the trunk may need adjusting. I read in other posts that the arm can be bent out of shape fairly easily.
Interesting to hear this. I have been considering a homegrown version of the electric setup. Without accomplishing a look at a wiring diagram, typical installations similar to this led me to believe the switch is for the warning light and / or interior light. Not the circuit to unlatch the cover.
PK
If you want I can tell you how I did it. Take a look at my posting about lighting up my frunk, trunk, and saddlebag. The microswitch is used in both the actuator circuit and the frunk light circuit.Interesting to hear this. I have been considering a homegrown version of the electric setup. Without accomplishing a look at a wiring diagram, typical installations similar to this led me to believe the switch is for the warning light and / or interior light. Not the circuit to unlatch the cover.
Good point! :agree:When I bent the actuator on the switch for the frunk I got a warning on the dash that the frunk was open.
I would think if that was your problem you would see a warning.
Bob
????? There is no warning for the front trunk, only the rear cargo compartment and the side luggages.When I bent the actuator on the switch for the frunk I got a warning on the dash that the frunk was open.
Bob
