Have you ever thrown a cold drink in your frunk and taken a ride then tried to drink it? That frunk sits directly between the radiators, and it roasts anything that you put in there. I decided to add some insulation. First I grabbed some foil backed bubble wrap I took out of my hot tub last time I was working on it and cut it into these shapes.
Untitled by Uncle Grr!, on Flickr
Then I sprayed it with spray adhesive, and did the same on the outside of the frunk. Stuck it on, smoothed it down.
Then I cut out this shape for the back.
And once again used spray adhesive to install it.
I only did the bottom because it's actually a pretty tight fit in the bike, but since BRP saw fit to add the foil insulation they at least understood that they had a problem. I haven't tested it yet, but once again it was zero dollars so if it works at all it'll be worth it.
