Magdave
His explanation was it is cast that way :yikes: If you look closely at the video his does it a little too you can see the belt move in and out just a touch. BRP uses a point from the frame for the front alignment ( pre 2013) 2013 is another beast it is supposed to have pre load brackets installed and done after the rim is off using their new laser system. All this is just "what I heard" never seen it done.................I think on the sprocket thing on you Spyder some possibilities are : a tech at your dealer mis-aligned the parts on re-assembly and has damaged them......the parts were not machined correctly in the first place ( I don't think this was likely )....Mike :thumbup:
