Alignment
ARNIE R
So, anyway, I have been wondering for a good while over whether or not my Spyder was truly laser aligned as my dealer said it was last year. After getting over the usual highly sensitive steering issues that occur, I had them check it about 2 months later after purchase. They told me it was "just a little off" but within specs.
A few K (8000K) later, both Kendas had scuffed their inside treads quite noticeably and were beginning to shake the front end. Switched to car tires shortly after that.
But, in the back of my mind, something still did not feel "right". The bike always had this tendency to very slightly drift to the right when letting go on the handlebars. The bars themselves would only move a very small amount, which was hardly noticeable unless you were staring directly at them. I attributed most of this effect due to the right hand crown of the road, however, testing showed that even on very flat surfaces or left hand crowned roads, the right hand "drift" was still there. And the inside of the left front tire only was beginning to show minor scuffing.
Today I rigged up a homemade laser "alignment" device and found the following; rear measurement at 61-7/8 inches, front wheels at 61 inches, and approx 4 feet in front, 60-1/4 inches. Surprisingly, the right wheel was had more toe in than the left wheel did as measured from the rear center line.
So, I loosened everything up and set the toe in to about an 1/8 on each front wheel. I will give it a highway test in a day or so.
Can't wait til a dependable source of a correct laser alignment becomes available because sure isn't from my dealer. :spyder:
ALIGNMENT
Scuffing on the inside edge of the tire is clear signal that A. it wasn't Aligned or B. whoever did it , didn't know how to do it ......:banghead:...... Mike
FYI; I can let go of the handlebars and the bike will go straight providing the road is reasonably level. Before alignment, I was fighting to keep a straight course......more than I realized. After Joe Squared Away my bike, he told me I should be able to ride just using my fingertips. He was right. Makes a world of difference. Good luck
Agree Canamjhb!! Arnie - Ann and Joe at Squared Away are amazing. My bike rides so much better. I would highly recommend if you are going to a rally or if they will be in your area you check them out! Super nice and super fantastic service!
If they were quoting BRP "specs", then that's not good enough.
The recommendation of the laser alignment maker and a LOT of shops with experience indicate that the best setting is outside of BRP's specs.
It's covered here in several threads.
Proper alignment really works!!!
Same here!!
Just got back from Topaz Lake and rydes to Mammoth Mt., June lake loop. I could easily drive with a couple of fingers holding the bars straight. No "squarrlyness" in the many curves.
Thanks again to Joe and Anne of Squared Away.
Lew L
They are going to be in SC pretty soon. If you can make it over there have them do your bike. Look for the thread "Squared Away to SC" and that will tell you where and when.
Laser alignment
I’m hoping to get Laser Alignment soon, I have a few questions to anyone who’s had that performed.
1) How long does it take them to complete the alignment (approximately)?
2) How long does Laser Alignment last, do u have to do it every time u get new tires/annually?
3) What does it usually cost, ballpark?
I know everyone who’s had it done was glad they did, and noticed major improvement. My problem is the closest shop is about 3-4hr drive (I’m not retired...yet). I’m also considering the sway bar that everyone upgrades, I was hoping to get both done during same appointment.
Thank you.
Jarred.
1) How long does it take them to complete the alignment (approximately)? About an hour
2) How long does Laser Alignment last, do u have to do it every time u get new tires/annually? Until you knock it out. My 1st one lasted a year until I hit a dog
3) What does it usually cost, ballpark? about $125 and worth every penny
Thank you.
Jarred.
I typed this and I don't know what it says so I erased it.
As a guess, can not accomplish an accurate alignment on a Spyder in an hour for $125.
There is only ONE adjustment.
It is my understanding that if the equipment is already set up, it would take about 15 minutes.
And $125 seems to be in the ballpark of what is usually charged.
Yes and no. Truely two adjustments left and right tie rods may need adjustment to set toe. Plus a BUDS reset for the steering once the alignment is set.
Agree that a qualified person familiar with the task should have it done well in short time. Not sure that 15 minutes would accomplish start to finish when you factor in moving the bike into place and paperwork, but maybe.
Not sure how many shops leave everything set up, but maybe they do. This alignment setup is very portable and easily stored, unlike a car alignment setup, but who knows, not I.
Netzley
Netzley Tire will be at SpyderQuest. I contacted them. They can do my laser and sway bar the day I get there (Thursday) so I’ll be good to go for the group rides. Can’t wait. Thanks to everyone who helped me understand this procedure/product.
Re alignment
G
Well I think you guessed wrong the inventor of the Rolo Laser Aligment system used to align the Can Am Spyder says it should take an hour or less and people who aligned my Spyder Squared Away did just that a great job
G
Pretty certain that the reply is correct in regards to the post it was referencing.
If you read the next few posts after that one, I did state an experienced person could do it quickly.
Takes me about 10 minutes if I hurry, to align a Spyder with my setup. So it certainly is an easy task and can be quickly accomplished.
