inspectsir
Just got new front tires (Vredestein Quatrac) on the RT. Running 20 psi and getting some bounce. Should I lower the pressure?
It depends on what is causing the bounce. If you hit a bump and it bounces too much as a result, lowering tire pressure should help. But if it's just bouncing for no apparent reason, then you're probably looking at an Out-Of-Balance tire. And tire pressure will probably do little to correct it. Alignment, though very important, probably won't help with this particular issue either.
Be sure the tire is fully seated on the bead of the rim, inside and out. I've seen this cause a balance issue. Did they balance the tires when they mounted them? Spin the tire by hand off the ground and check for roundness. This will also show a bead seat problem. Vredestein makes an excellent tire. But no one is perfect. Could be a bad one.
Hope it's a simple fix.
:agree: .... That Q-5 could be bad , but it's not likely..... not all spin balance machines are created Equal, and IF they arn't checked for calibration periodically, they may not give accurate info, also the person doing the balancing may not know how to use the machine properly. good luck .... Mike :thumbup:
Yes you need to lower the pressure some (16-18 psi). Was the tire balanced? Also was the DOT lined up with the valve stem? .
Did you furnish the tires or the place that installed them? I would take it back and have the balance re-checked.
K80Shooter: Can you explain the need to line-up DOT with the valve stem? I have never heard of doing this.
Thanks.
Good luck finding a tire shop or car dealer with small enough cones to fit the Spyder front wheel holes. Mine are slightly out of balance so I called or visited every tire place with an I-force spin balance machine and their smallest cones were too large, The center holes (on the 2021 and probably others) are 1.9" or 48.5 mm.
I know my Can-Am dealer (100 miles away) can do it, but they are running 6 weeks out with only one tech. I may try a bubble balance that I can do myself and see it that makes a difference until I can get an appointment with the dealer or LaMonster.
You live in the wrong part of the country. Many tire shops and full service garages here will mount and balance. I went to favorite and they were happy to do it all on a ride in basis.Good luck finding a tire shop or car dealer with small enough cones to fit the Spyder front wheel holes. Mine are slightly out of balance so I called or visited every tire place with an I-force spin balance machine and their smallest cones were too large, The center holes (on the 2021 and probably others) are 1.9" or 48.5 mm.
I-force not needed on tires that carry such a light load compared to cars and trucks.-so I may check one of my places that has an I-force balancer and see if they will let me do that. Thanks!
Easy there Mike. Yes, tires need to be balanced, no question. But the I-Force is not for the lightly loaded tires of a Spyder. IMHOI find this contrary to everything I know about - Why front tires need to be balanced.....:
