merlot
Hello all. Does anyone know how to remove the bolt holding the sprocket in place? Even in gear the shaft still moves when I am trying to loosen bolt. The sprocket has the belt attached and it doesn’t move so it is definitely the sprocket or shaft.
PMK advise should work if you do it properly
if not you would need to hold the clutch basket,not the pulley
when i refitted my bolt,i removed the yellow thread locker from it and used fresh blue loctite,but i do plan to check this component every 10K Kms
russ
