SpyderWolf
Thanks for posting this. It just adds another reason I need to go buy a torque wrench.
If you don't have a torque wrench here's an old mechanics trick.
Tighten till it strips, then come back a 1/4 turn.:roflblack:
lucky enough to get them out. Those allen head screws holding in the oil filter are a pain.
I just checked 2 08 SM5s and 1 09 SE5. I checked the torque at 60, 75, 80 and 89 and they were all tight... not one of them moved. However, I did not loosen them before re-torquing. Should you loosen them a bit and then torque or just torque them from their current torque. They all clicked the wrench at 89 and I did not go any higher./Ken
Yes, 1/4 turn. :doorag:Should you loosen them a bit and then torque or just torque them from their current torque.
Does anyone have a copy (scanned) of this service bulletin as a picture or jpeg?
If so, are you able to post it here, or please PM me.
thanks
Did anyone ever get a scan posted of this service bulletin?
After a fantastic long weekend at 70 mph in moderate traffic, you will lose power to your bike. Your belt falls off and hopefully you are going downhill and able to coast into a Chevron 6.5 miles south of a dealership.
You will get off of your bike and wonder what the heck happened. But of course you think it is somehow related to the fact that you just changed out your rear wheel prior to this excursion. When you go to put the belt back on, you notice there is no sprocket in the front.
Hmmmm, I've gone exactly 12,004. You talk your buddy into riding back to the dealer for a truck and trailer. Your trip ends with you riding two up on the way home and poor Spyder left at the dealership. The head of the bolt sheared off, and the sprocket was flung up under the bike somehow.
BRP and the dealer come thru with free tow, free fix, and a topped off fuel tank. Service doesn't get any better than that! :2thumbs:
His belt came off because his front sprocket came off, not because the belt was loose. Don't let your tech second guess BRP's new spec. The old spec was 1500 + or -, but it was deemed OK if it was 1100 upon inspection. The RT spec came out at just half the original spec...750 + or -, just a few months ago. Now BRP has seen the need to cut that even further, to 450 + or -. There has to be a sound reason and some engineering knowhow behind this. I would not take your tech's word for his idea of safe. No disrespect, but he has not studied this the way BRP has.Are you guys serious? The belt came off? Come on!
The tech lowered mine from 1300/1400 to about 900...said would be safer than dropping to 400-600...
This made sense to me so I left the issue alone...
