RydeOn
I was driving my 2012 RT yesterday to an appointment that I had in town (about 7-8 miles away). The drive there was nondescript.
However, when traveling back home at about 9:30PM, I was coming down hill going about 35 MPH when the front end started shaking like I’ve never experienced.
At first I thought one of the wheels were coming loose. I immediately slowed down and the shaking stopped. Then I thought that perhaps I simply hit some corrugation in the roadway which caused the shimmy. I came to a stoplight, then when I sped back up the shimmy started again. I slowed down and kept it to about 30 the rest of the way home.
I didn’t have time last night to see if anything looked out of order, or to check to insure the lugs were all tight. I’m not a mechanic by any stretch of the imagination, so something would have to be VERY obvious for me to recognize if it was out of place. nojoke
I’ll check it when I get home from work today.
What would cause a shimmy like that? I have felt a bit of shaking before on the freeway between about 65-70 MPH, but it is mild and does not feel like the front end is going to fall off. The obvious things I’ll check is to make sure all lugs are tight (I’m able to do that with my excellent skill-set). And I can see if something (obvious) in the suspension seems to be off or broken. Other than that, what might be the cause??
