Mine was over 9" out at 74". :hun:
Anyway, for the sake of discussion, I've been surfing around and calling Can Am parts dealers looking for wheel bearings and a tie rod end, since it appears the outer ball joint is what is loose. I've discovered that you can not buy just the tie rod ends, you have to buy the entire tie rod. I'm a little pressed for time, so I'm not going any further than buying a tie rod, however, I think I made an interesting discovery. That being the front end of the Spyder is borrowed heavily from BRP's already existing ATV's (Outlander and Renegade) and if you look around the those parts catalogs you find you CAN buy just the tie rod ends. I'd be willing to bet they'd fit just fine. $107 vs $37 (retail pricing).
Also, since I've researched further into the hub bearings, I will sort of, kind of, retract a LITTLE of my rant about their design. I now understand more fully what they did. The bearings they used are ball bearings, they are technically called "double radial ball bearings". They are stronger than the FM photos make them appear, HOWEVER, they are not appropriates as a wheel bearing. I am correct about the loadings, because those bearings are designed for electrical motors that have NO side loadings and run at high RPMs. How BRP decided to put them into a wheel hub, first on ATV's and then onto a road going Spyder is beyond me. Now clearly they do work, as evidenced by high mile Spyders out there, but I'd be willing to bet that if checked carefully there are a whole lot of wheel bearings that need servicing (RE: replacement).
