Front Directional Signal Wiring
slyder
I am installing the Magic Flex Channel lights, is anyone aware of an easier access to the front directional signal wires other than removing the dash. Not an ace mechanic, so looking for an easier way. Installing on a 2012 RT
I taped into my mirror turn signal wiers wasnt to bad to get the wier up there. am sure others will chime in. Good luck
We did the same. Our instructions said to tap into the signal wire behind the left mirror. Wasnt that bad and you dont have to mess with the dash.
Sent from my DROID X2 using Tapatalk 2
Did you purchase the channel lights from Custom Dynamics? If so, they sell a Tips Kit that connects to your turn signal wires that go to your mirror turn signal lights. The Tips Kit makes your fender tip light into a turn signal as well as any other light that you connect to the fender tip light wires, like mud flap lights and brightsides.
