From RPM to the temp
Gimpy Girl
I had the DPS update done and picked up the scoot today. It's now showing the RPM's rather than the outside temp and I miss seeing the temp! Any way to change it back to showing the temp??
I was trying to get the temp on for over an hour, than the 12 year old boy came over from across the street and set it in about 10 seconds. He and his family has since moved and after my last DPS replacement, not the new one its gone and now have to find another 12 year old.:D
For some reason whenever I pick up the :spyder2: it is always on the RPM setting as well . So out comes the manual and all is well .
Probably not - but I need to the owner's manual to tell me to hit the "S" button and for how long :opps:. Although, sometimes mine will run through easily and then other times I have to go through the sequence several times before it will "take".
The "S", select button toggles between the temperature and the RPM in normal mode.
Hit "S" on the cluster to switch.
cheers.
