For those SM folks....
Chupaca
Recently we saw some clutch problems having to do with fluid and shifting. Here is a quick check for that. There is a small cover ...20170314_122917.jpg this cover has a weep hole but you can also take it off for confirmation. 20170314_122933.jpg mine was leaking and running low on fluid making shifting sometimes difficult. Decided to wash the engine and change the o rings. Caution on this step...you have to hold the center screw with a 5mm Allen while you loosen the 17mm nut. If you don't you will damage the diagram for the vacuum assist system...20170314_132342.jpg then pump the lever and the piston will pop or fly out best to have a towel over that area. Clean all parts change o rings reassemble and refill and bleed. 20170314_132352.jpg all is well once again....:thumbup:
Chupaca, thanks for the post, you always seem to offer a lot of very good experience and I thank you for that.
On another note I would like to say that you seem much wiser than your picture implies. :roflblack::roflblack::opps:
Joe
Thanks....
Like I told my kids while growing up....I'm old thats why I know. Sadly by the time we had our youngest I was as old as all her friends grand parents....:roflblack: good thing the wife is soooo many years younger....:bowdown:
Joe
Well....
I used to raise them in south america...his name was Professor...maybe in my older age I will get another, when I know I will not outlive them...:lecturef_smilie:
:D Gene is WAY smarter than the average Basset Hound... :clap: :2thumbs:
