Fog light bulb replacement
dcspyder
I am a new Spyder RS owner and was curious about what panels need to be removed to replace the fog light bulbs or does the trunk have to be removed?
Its relatively simple & No the trunk stays on. Which ever side bulb is out you will need to remove the 2 front side panels starting with the one close to the seat. there is something like 5 screws and 3 or 4 plastice push type fasteners on the forward panel. should take 5 to 10 Min. to do. Hope this helps
welcome This is the place for all your :spyder2: questions and concerns.:congrats: and :f_spider: on
welcomeHere is a suggestion. If one of your OEM fog light bulb crapped out, perhaps its an oppertunity to upgrade instead of replace. Since you are going thru the motion of working on it, you might as well upgrade yourself to something better such as ESI's HID bulbs. Brighter and gives much better visibilities. Just a thought. I know I am waiting for mine to crap out before upgrading.:spyder:
