Fobo won't install properly? Any ideas?
shoppersal
I purchased FOBO for my tires have 2 out of 3 installed. For some reason cannot get the front right installed. It tells me it belongs on a different tire, or if a friend is around that have FOBO's installed on their bike then it tells me it belongs to them. Does anyone have any idea how to install it ? My friend has them & her back tire fobo doesn't want to be installed . I have a 17 RTL 51,000 miles. She has a 2020 RTL Thank You!!!! Sal Quinter
Most FOBO's come with a spare set of batteries which are not much better than the almost dead ones inside. Get brand new batteries and try again. If one is telling you it belongs to a previous bike then it's a returned set and either release them from your phone and return them or talk to FOBO support.
Had a similar issue with mine when i went to install my air shock one. what i did was pulled one of the front tire ones off and moved it far away and stuck the shock one on the tire and programed it and then moved it.
My FOBO 2 installed perfectly on my RTS. I find it perfect for my needs. Sorry to have heard your misfortune and hope that you get it sorted out.
Fobo install
I had nothing but trouble installing the Fobo tire pressure sensors on my 2018 Can-Am Spyder F3-T.
I finally figures it out. I needed to take the phone case off of the phone. When I did that they installed instantly.
Hope this helps
Mike
Hope this helps
Mike
That’s interesting, Mike…… I have had two different phones, with a couple of different (and thickish) cases on each of them and never had an issue with “connecting” to the unit over 4 years. Who knows :dontknow:
Pete
