Fobo tire pressure gauge on the airbag.
WaltH
Senior Member
Has anyone tried to use the Fobo tire pressure gauge on their airbag (RT and F-3)? If so, what are the problems, and how did it turn out?
You can buy a 4-sensor system (or an extra sensor), and there is a setting in the "new profile" menu for "Reverse Trike + Airbag". If you already have a profile set up for three sensors, you'd probably have to delete it when you add another sensor and set up the new profile.
I only have the three on my tires, but I think finless is using a sensor on his airbag also. You may want to contact him.
I am using one on my RT air bag
I have no problems with the sensor
One added advantage is it tells me the compressor is working
