Fluid temp vs MPG
Desert Spyder
I've been noticing lately that the colder my water temp is the more fuel is being consumed. And of course when it is warm the less. I know on cars there is a sensor to richen the fuel mixture so to warm up the vehicle quicker. Is it the same on the Spyder? Yesterday, I went on a PG mission "down the hill" which has been enjoying 80 degree temps lately. My temp gauge on my RT showed rough half way. I drove about 120 mi and got about 35 mpg. Coming home in the desert the outside temp was in the 60's, my water gauge showed about 1/4 up (analog), and I got about 28. Why? Also, last summer I added a little "Engine Ice" to my fluid because of the high temps out here in the desert. But in the winters, when the temps drop below freezing and stay in the 50's during the day, my fluid temp may barely show any rise at all when cruising on the freeway. And of course the mpg drops. So whats going on here? I'm sure there are many owners out here who may be in the same "boat".
Very astute of you to notice the fuel economy change correlation with the temperature change! :firstplace:
I'm not sure if it's the fluid temperature or the air temperature that enrichens the mixture to keep things happy, but I'd guess that it's the latter. :dontknow:
Quick mixture Primer...
Cold, denser air requires MORE fuel to keep the mix correct
Warm, less-dense air requires less...
That's why we get better fuel economy in the summer! :thumbup:
While mpg does vary with the air temp and density, there are too many variables here to attribute it all to the temperature. Which way was the wind blowing? How strong? Minor variations in filling the fuel? Different fuel from different staions? Uphill one way? All these can affect the mpg you calculate, especially over just a couple of fills. Gas mileage almost always is different in one direction of a trip compared to the other, due to the wind and the elevation changes alone. Only a long term, controlled study can prove that what you suspect is actually true. :)
The Spyder's temperature gauge is much more sensitive than the average automobile (or other motorcycle gauges). What appears to be a big swing in temperature is not all that much. The coolant system thermostate keeps the engine temperature to at least normal operating temperature.
I am doubtful that this is the reason for your mileage change. I usually find mileage is better with colder outside temps, which makes sense because cold air is denser and gives a better charge to the cylinder. But this is a generalization and other factors have much more effect.
AIR TEMPS
IMHO, Colder is better power wise anyway....back in the day I knew guys who would put ice in the air cleaner housing for that little extra ???....Mike ...:lecturef_smilie:....:gaah:...:thumbup:
Don't know about the air cleaner but, Back in the 60's i made my own cool can's, I would Spiral a few feet of fuel line in it then fill with ice. Kept my ET,s down in the summer at the strip.
Yes, we used to solder in a copper coil in to an old tomato juice can that we filled with ice. it helped on the quarter mile but no differnence on trips. Not sure if I remember this correctly but I believe the cold gas takes up less space than normal or hot fuel so when the fuel enters the cylinder it expands, taking up some of the space. This resulted in a bit richer run off the line so I believe we used to compensate by leaning the air/fuel ratio bofore the run (for the street rods). Cooling the air technically would have the reverse effect, ie allow less room for fuel but with modern knock sensores, oxygen sendsers, electron timing control and all the other goodies the air temp should have little or no effect. The winter blends of fuel do make minor impacts on fuel milage both gas and diesel. It is more notible in diesel, my 2005 F250 drops from 16 in town to 14 when the winter fuel enters the scene.
Regards,
Question: Throttle Bodies... Aren't there more advanced systems being used today to get the fuel and air into the compression chamber?? :dontknow:
You might be thinking of direct injection, but they still need some thing to get the air mix in.
Just about any [road] vehicle you can buy comes with throttle bodies,.
That said there will always be advanced systems coming along every day.
Awhile back there was a guy in India who was running a small car with an air compressor.
The cylinders were pushed by Compressed air, The compressor was run by a Kerosene? generator.
One day some nut will come up with a billion dollar idea. ie; Remember Edison:thumbup:
I like the way that you think, Mike! :thumbup:
But I guess I was thinking of something that us mere mortals could use without having to get too "mechanical"... :shocked: :roflblack:
COOLER IS BETTER ??????
Mike in Ga. You are absolutely right......In Antartica my Boss "429" with the shaker hood would't work worth a damn......Ford just couldn't get that right.....or the Talledaga either......:roflblack::roflblack::roflblack::roflblack::roflblack::roflblack:.....Mike...:gaah:
Yeah, but then the oil co.s put a hit on them :roflblack:
Sorry Mike, but you're off a bit.........
Cold, dry, air at sea level is the most dense, with the highest oxygen content. Air with a high moisture content is less dense, as the water vapor molecules displace the air molecules, resulting in less oxygen available for combustion. Hot, humid air is the worst for performance, and dew point isn't really a factor....
Colder ambient temperatures will result in the Spyder's ECM increasing the fuel delivery to the cylinders because of the added oxygen available. This would result in better performance, so theoretically, the MPG should balance out. The mixture isn't 'richened', the fuel/air ratio would stay the same. Having fun with the increased performance might result in an MPG reduction.......
Ahh... Reason, reality and proven fact.... You don't stand a chance with this approach! :roflblack:
Well, I don't completely agree with either of you. Here is my understanding of this, partly gleaned from many years of racing.
Cool, moist air is the most dense, but moist air does not hold as much gaseous oxygen per unit volume, so it may not work the best. The oxygen (and hydrogen) in the air are not usable in the combustion process. The water is merely turned to steam. Too much moisture and the engine suffers. A little is good, though. BTW, if engines could run on the hydrogen contained in water, we wouldn't be using gasoline.
The EFI will adjust the amount of fuel delivered to match the fuel/air ratio called for by the mapping. Denser air requires more fuel to keep the same ratio. The actual volume of air taken in remains constant, as it is a product of the volumetric efficiency of the engine, but the amount of oxygen is greater in the denser air, so more fuel will be required. (Note: engines with variable valve timing can change the charge volume.) You will generally use a bit more fuel at lower altitudes and higher air densities, as a result. Other variables, like fuel mix, grades, wind, and the fuel composition will affect the mileage, too, often far more than mere air density. As was said, the peppy feeling you get from having a bit more fuel in the denser intake charge, often results in involuntary twisting of the throttle, which makes the most difference in your fuel mileage.
So, here we are with three somewhat different slants on the same phenomenon. I won't say which of us is right, if any, but I will say that I have not been convinced enough to change my understanding of the process. JMHO
After spending 33 years in the fire service I can say that I've put water on a lot of different kinds of fires, and it never burned one time. There are some fires that you don't want to put water on (like a petrolium fire) but not because the water burns.
It may be that this reference was to the expansion rate of water to steam which is a very impressive 1700:1. This will give you some substantial energy release in the combustion chamber, but as soon as you get steam you're going to put out the fire producing the heat needed to make the steam in the first place.
It does appear, however, that we may have strayed a wee bit from the original purpose of this post.
