Oldtimer51
Question on the floorboard latch. What was the original #BRP reason for that sytem? Were they concerned that the brakes will fail regularly that this system would be activated and therefore was required to be there? I noticed that the bottom portion of the latch is longer than neeeds and sticks out under the 2008 RSS (at least) and has been hit with the ground and I assume has released the floorboard that triggers a "Brake failure" indicator in the dash. According to the owner It goes away as soon as the Spyder is restarted and the floorboard pushed back in place without any signifiacan change in the braking system operation. I noticed while working on this one that the Brake Master Cylinder is about 1/2 inch next to the hot exhaust pipe that does increase the temperaure of the fluid inside the Master cilinder and in long hot rides could change the viscosity of the brake fluid and decrease the braking efficiency or cause a complete brake failure. The Master cylinder has a small heat shield but I dought it that it does anything significantly. I wraped the lower portion of the exhaust with high temperature wrap shield to see if that decrease the occurence of these mistery brake isssues and floorboard dropping down. Any suggestions are welcome. Or any similar observations from other mechanics in the forum are appreciated.
