Flat tire kit
Repair Kit
For my tire repair kit:
1. Plug kit
2. Fix A Flat to inflate and help seal the bead and plug and replace the can of Fix A Flat (A.S.A.P.)
3. 12volt air pump to top the tire pressure (35psi rear 25psi front, then adj. to back to normal after 15 min.)
That's IMHO
Mike
I'm curious, those small compressors, will they put out enough air to fill that big tire?
I mean before running out of battery
battery ???
............................................................................................................The 12 volt compressors run off the Spyder Battery and I would just leave the Spyder running while you do this to be safe ( about over using the Battery )................Mike :thumbup:
power outlet in rear trunk
No you have to install one , on mine I got the idea from SL on one of the speaker cover.
I have a 2014 RT-S and there is a cigarette lighter style outlet in the rear trunk on the left side (as you look into the trunk). I use it to charge my phone while riding.
I was thinking it would take a long time. but 15 minutes has to be better than all day
