flashing cam an on dash
Thundercat
Battery went dead and was replaced. Bike fire right up now but the dash just lights up can am then will go blank and repeat. I've pressed the mode button. The bike will start without pressing the mode button. Is there a reset somewhere.
I checked the grounds they appear to be tight I even wiggled wires with the bike running with no change. The dash continues to flash can am.
Could this be a DESS issue? Is this one of those cases where the battery has to be reconnected, key pulled out and "taken for a walk" while the battery is reconnected and system resets? Just asking for my own knowledge as well.
I still believe you have a bad/disconnected ground.
Since you replaced the battery it was logical to assume it was there but it could be anywhere.
Someone else recently had some odd electrical problem, almost think it was the same flashing screen.
As I recall, there are two ground wires and the other topic found that the person only connected one ground wire when they replaced the battery.
Don't kill me if I'm wrong...
PK
Both grounds are hooked up. I tried the key away from the bike thing but then I remembered I have the spare key in the frunk. So I'll try it again tomorrow. I'm suppose to ride about 160 miles tomorrow do you think it will be ok? I hate to take this thing to a dealer and find out it was something simple.
A constantly rebooting display module can't be a good thing for longevity. Yours or your Spyder's.
OK checked every ground I could see, wiggled wires, unhooked the battery several times no luck. Guess I'll have it towed to a dealer. Sad thing is the closest dealer is about 100 miles. Thanks for all the help. I'll let you know the turnout
Did you check the negative and positive jumper posts under the seat. Make sure it is tight. Warning do not loosen the negative if it is tight. It is a bear to tighten again.
If you have a volt meter. It would be interesting to know the voltage of the system. At rest and with the engine running.
Here's something to try.
1. Connect one jumper cable end (use black for example) to the Negative Post of the battery
2. Connect other end (other black end) to some point on the frame like the rolled gas tank lip running under the tupperware.
Try starting it & see if the reboot happens.
Here's why I still believe probably have a ground problem.
I realize there could be wide variations in voltmeter accuracy or even how you report the voltages, but having said that here's my take.
You should actually read 12.7 Volts at rest and something close to 13.8 at idle or above 2500 rpm.
If you don't there are three possible reasons that come to mind.
1. You are rounding off the numbers or have a free Harbor Freight Voltmeter.
2. Your charging system has a problem.
3. You have a high resistance ground connection that is eating part of the voltage.
My vote is number 3.
If you measured the voltage with respect to frame ground and not the negative terminal then the voltage gap of a half a volt or so is significant.
The display will reboot if it sees a voltage of less that 12.4V or so and the only reason it would see that would be either your charging system isn't working (stator or voltage regulator) or a bad ground.
That's my story and I'm sticking to it.
