Sorry for the long delay in posting folks, but work that brings in the cash must come first, got my hands full for the time being.... my system is working well so far, I haven't really got a chance to ride on a long deserted road to test exactly the speed at which switching points for fan reverse and forward occurs but from normal riding to and from work and glancing between the indicator lights and speedometer occasionally, I would say that it switches back to normal fan direction at around 40 km/h, but far more important is that it switches back to reverse at around 30 km/h... a difference of 10 km/h instead of the previous 2 km/h, which is good, so that rapid switching between on/off states of the relay is avoided.... the area of the paddle switch has been reduced to about 50mm by 80mm from a previous size of 76mm by 100mm..... I will find time to do some more testing before deciding whether to reduce it some more or leave it as it is....
In reply to poordom, and for the rest, my system works like this.... once you got stuck in heavy or stop & go traffic or you feel your right foot is getting too hot for comfort, just flick a switch and the cooling fan reverses direction and blows hot air from the radiator forward and away from your right foot.... the fan will continue blowing forward as long as your speed is below about 40 km/h, once your speed goes above 40 km/h the fan automatically switches back to the normal direction.... you can leave the switch as it is or if you are constantly riding at highway speed then you can flick the switch back to the normal mode, that is, no fan reversal... my system also has another override mode, where you can switch the cooling fan to run all the time, this has the advantage of at least bringing down the coolant temperature by one notch on the digital display from the usual 5, and the difference can be felt!.... so far, all I can say is, it works!....
