MtlBen
Since both fuel and temp gauges are grounded via the instrument cluster, I had a theory that the cluster would sense the ground return current to determine if any of the analog gauges were connected.
I disconnected the ground wires from both gauges and jumpered the instrument grounds back to the jump-start ground connector, bypassing the instrument cluster.
When I turned the switch back to ON position, both analog gauges worked fine, but no digital gauge in the cluster. I did verify my connections a few times before and after the test...
The cluster is using a different mean of sensing the presence of the gauges. :dontknow:
...Just in case you had the urge to test this yourself...
...Ben...
...Ben...
