Wildrice
F3's belt vibration stabilizer
At this time I do not have comprehensive info as to whether this modification solved the vibration problem. At low speed 3rd-4th gear at 4K rpm I still have a strong vibration on my footboards. More testing to follow. Attached is the upper roller assy with stock mounting bolt & 3/8" aftermarket longer bolt.
Darrell
I purchased the Baker belt stabilzer---as per shipped the upper stabilizer mounting bolt had approx 3/8" thread turns--which I felt somewhat less than safe. After mounting the chain guard I found that the mounting bolt would not grasp the securing clip. Distance of belt guard & recessed portion of mounting bolt & 1st thread catch was inadequate. I spoke to Bruce Baker & he advise to ream the belt guard hole out ot 3/4". That would allow the mounting bolt another 1/8" to grasp the inital turns but still lacked safety concerns for me. I purchase a 3/8" grade 8 2.5" bolt & securing hardware which appears to secure the mounting bolt safely. On my bike the Catalytic converter prevent the upper roller assembly to track the center of the belt---I am out of adjustment room to correct the adjustment.We at Baker Built have a belt stabilizer that will not add any more tension on the belt but will take the vibration out. Please check us out on our web site where you may view pictures of the belt stabilizer.
Thanks, Mike
Darrell
