F3-T Spotify question
eddiebrown
Hello,
I'm wondering if I can play Spotify and Google Maps via bluetooth while it's plugged in and charging
Thanks,
Eddie
Hello,
Thanks,
Eddie
I don't know what year your F3-T is but mine is a 2017. The 2017 does not have a dedicated BT connection, but I bought this :
Mpow Bluetooth Receiver, Portable... https://www.amazon.com/dp/B008AGQMQC?ref=yo_pop_ma_swf
It works great. You power it through the existing USB plug that's in the front compartment, so you may need an additional power source for your phone. You then plug the aux cable (that's also in the front compartment) into it and you can listen to whatever is coming out of your phone. Just connect the phone to this receiver via BT and they choose auxiliary on the Spyders audio setting
What year?
I have a 2016 F3L and have my iPhone plugged into the USB connector in the glove box and it plays anything from my phone - Google Maps directions, music from Pandora, etc. If you want to do the same with a non-iPhone device you would need to create a bluetooth connection which is easily accomplished by purchasing a cheap BT transmitter and putting it in the glove box or some other location.
Spotify and MyRouteApp Navi
Hi,
That's what I'm using.
If you look at post #3 in this link
http://www.spyderlovers.com/forums/showthread.php?107845-iPhone-connection-to-handle-bar-mount
you will see how I'm using it.
I pass a USB cable from the inside of the glove box to my handlebar and i'm using an x-Grip Ram mount for my phone.
I'm listening to Spotify and I'm also using my iPhone for navigation.
That way, you can also Play/Pause your Spotify with the control on the handle by just changing the source from USB to something else will automatically Pause Spotify and when you go back to USB mode, it will Play again.
No need for bluetooth and the phone is always charging.
