F3 Rear wheel jacking point
graeme.g.1957
Hi, I need to raise rear wheel to adjust belt tension but can't see an obvious jacking point. Anyone can advise where it is. Cheers, Graeme
Place motorcycle jack under frame member and lift the whole machine. One will need to experiment with placement to achieve balance front to back and side to side. One should also loosen the axle nut before the machine is lifted as it is tightened to over 160 ft*lbs and the Spyder will move on the jack with that force.
Wayne
