F3 or 2020 RT topcase dimensions?
Can someone please measure the inside bottom of their topcase on the F3 or the 2020 RT? I want to replace the rubber at in the bottom with a yellow mat for better visibility. I dont have my new 2021 spyder yet. Its due in january, but I am trying to accumulate all my parts. Thanks.
It is a fitted mat. Like the new car floor mats, do not believe you will be able to make a new one without a pattern. Good luck on your new ride.
Wow, that's one hell of a project. The entire mat is contoured(convex)to fit perfectly into the trunk. It has an irregular circumference, there is a large cut-out for the lock dial, another round cut at the top, a rectangular recess at the bottom and a lip around the entire mat. I wouldn't know where/how to start measuring this mat. I would never try to duplicate this mold......but, I'm not the one trying. :dontknow: Good Luck. mat.jpg
Wow, that's one hell of a project. The entire mat is contoured(convex)to fit perfectly into the trunk. It has an irregular circumference, there is a large cut-out for the lock dial, another round cut at the top, a rectangular recess at the bottom and a lip around the entire mat. I wouldn't know where/how to start measuring this mat. I would never try to duplicate this mold......but, I'm not the one trying. :dontknow: Good Luck. View attachment 186568
I can easily duplicate it, but need the widest dimensions. Length and width. Thanks
Another consideration is what to do when your water bottle empties into the top case. These things are water proof. After draining my spillage I drilled a hole in the deepest part of each channel (there are two channel) to provide drainage if spillage happens again. All hidden from view, unless you are specifically looking for the drain holes.
For goodness sake......I know people are trying to be helpful, but can’t someone spend 5 minutes and just measure the widest and longest dimensions of their ‘20 case bottom for Joel? That would answer his question. :dontknow:
Just went and checked, 21 1/2 inches wide x 16 inches front 2 back, you must work for weather tech if its that easy to duplicate!
