nslowmotion
Engine oil check shows that oil viscosity is breaking down even when oil is changed at 4000 miles. Time to shorten intervals and go with full synthetic oil.:banghead:
BRP oil wont make it fully to 4,600 miles based on testing I have seen.
Amsoil gets there "almost" again based on testing.
Go 100% synth... I did and won't look back.
FYI, rumors are flying all over the place that the 1330 engine does not do well on Amsoil.... I sure wish someone would substantiate that rumor!
Bob
I am about to change my oil in the next day or two and 4400 miles on a crankcase of XPS Synthetic Blend. I am having it analyzed and will report. Am also changing to Mobil 1 10W-40 that I will change at same interval and will also have analyzed. Why? Curiosity and to gather data on different types and brands.
Bob where did you hear this ????....I read ALL the oil stuff.........Personally I use the Rotella T-6 and will test at end of summer .....Mike :thumbup:
Ensure that you use the Mobil 1 motorcycle oil. The car oil will be a bad choice.
PK
Oh yes, the 10W-40 Racing 4T is on the work bench.
Ok I'm new to the spyder and this site, but I have 700 miles on my 2015 rts when should I take in to have service done and should I tell them to go with a different oil?:agree:.........But this is OLD news......Doc Humphrey's (?) tested His months ago and found the same thing in the 1330 engine ......Mike
The Mobil 1 4T is in the engine and gearbox on our machine. Even went all in and bought Dimple magnetic drain plugs.
PK
Bob
Bob
