Engine Ice
The Bakerman
Does anyone know if BRP will void the warranty if Engine Ice is used? It is reallly hot and humid here in Alvin, TX and I was looking for ways to keep my 2011 SE5 cooler, especially in trafffic. I know about Spyderpops add ons, but I wanted to try and start simple and cheap if possible. I've read alot of good things about Engine Ice, but never used it before. Any feedback?
Thanks and ride eyes open...
Doubt anyone can answer your question. Except BRP. Your owners manual makes recommendations on what to use. BRP recommends a ethylene glycol based product, which ICE is not. Pretty much your call unless you ask BRP.
Out of all the things people put on or take off their Spyders that would be the last thing I'll worry about losing a warranty over.
Its a good product lots of people have been using it in all kinds of vehicles for years with no problems.
Brakeman I have the same hot,and humid weather here also, the spyder has never overheated in the two and half years I have had it at times wil get 5 to,5/2 bars but the fans kick in and all is good. I won't but any thing brp does not cover in manual not taking any chances, to delicate of machine, and don't want any warenty questions.:yes:
Difference
Is there a difference between E.I., and "Water Wetter" ????.....Mike....
Engine ICE says it is to be used in replacement of ethylene glycol products and recommends never mixing the two.
Watter Wetter says when added to ethylene and propylene glycol systems it improves heat transfer.
Beyond that - is their a chemist in the house?
Engine Ice is great stuff! :2thumbs:
I used it in a 660 Grizzly that we "686ed" with no other change to the cooling system and it ran cooler than it did when stock; even when just plonking down a trail at walking speed with little or no airflow through the radiator.
ok i don't know what all this stuff is that your all talking about can you give me some details as to what all this ice and watter stuff is and where is it applied to?
thanks
Your machine should not be overheating in any kind of weather. If the fan is operating as it should, the engine will not overheat. You may see the temp indicatior move up a bar, but that does not indicate overheating. I took a ride yesterday with the temp hovering around 105 with an indicated 115 on the dash (black top road) with no problem. If your Spyder is shutting down with overheating code have your dealer check it out. This is not to say the heat rising off he Spyder does not get uncomfortable for the operator, it does. Heat off the engine is just one of the things all motorcycles have in common. As to Spyderpops, they have a product that forces more air through the radiator at speed, as well as products to route hot air away from your feet. Both work well, unfortunately in stop and go city conditions they are of little help, as the fan only is moving the air while stopped or moving slowly. Be very careful using non BRP approved products. If you check various threads on this site you will find that warranty issues become troublesome when engine or fluid products not approved are used. Having said what I did, Engine Ice is a product with which I am not familiar.
I added about half a bottle of "hyperlube" about a week ago. It received good reviews from what I've read. From what I've come to understand is that it's not a FIX for overheating, but it helps and won't HURT. It was cheap and put a smile on my face at the end of the day....:coffee:
It is the same color as regular antifreeze and I cannot imagine how a dealer would ever know it was in there. So warranty concerns are a moot point as far as I'm concerned...
Thanks everyone for your input and advice. I think I'll just stick with BRP recommended products. Don't need the hassle.
