kalavera
While I had my panels off, I decided to look around. I couldn't see the level of engine coolant from the front. So I looked from the left side with the lower and upper panel removed. I noticed my engine coolant was near the minimum.
My question is can I use the same engine coolant I use for my car? I wasnt sure and found in the book that said, BRP Premixed Coolant (P/N 219 700 362) or coolant specifically designed for aluminum engines.
Huh? I didnt know there was a difference until I read that. So, what shall I use?
