Grandpot
Many RT owners have had problems with the seat latch releasing with the key and then finding it is extremely difficult to circumvent the system. Here is a cheap and easy way to set up and emergency release cable. All you need to do is get some bicycle brake cable and drill one hole. The cable can be found on Amazon for about $12.
Run the cable as shown. Hook one end to the existing latch and run the other end along the frame and out the hole under the right headlamp adjuster. When you need to use it, just remove the right side cover and give it a tug.
These pictures are from my 2011 RT-S.
