Elka ?
robspyderden
I have an 2013 spyer rt-s.
I would like a better handling for cornering and riding two-up. I'm considering these two options
1-Bajaron Sway Bar with Elka Stage2
or
2-Bajaron Sway Bar with shock adjuster on the oem shock
Any input to help me make a decisions is greatly appreciated.
thanks
Depends....
On how much you want to spend. I would do the BajaRon sway bar to start with and after a few hundred miles move on if needed. Again I would go with the shock adjusters trying the different levels. If that doesn't do it spend the big bucks for the elkas. jmo the high tech shocks, though a great improvement , do tend to have issues and need maintenance which is not cheap and the oem, though sadly lacking, don't...:thumbup:
I would definitely go the route of the sway bar first. I believe it makes the biggest difference. I have not gone the adjuster route but may consider it. I had Elkas on my first 2011. Keep in mind the Elkas will eventually need service and ALL the other options one one and done items!!
