Elka shock protectors
docdoru
How and where do these attach and did they come from Elka? :D
[FONT=Arial Narrow,Arial MT Condensed Light,sans-serif][/FONT]
[FONT=Arial,Helvetica,sans-serif]Elka Suspension is unveiling to you their new SHOCK PROTECTORS:
[FONT=Arial,Helvetica,sans-serif]PRODUCT FEATURES:
  • Lightweight shock protector made of durable polypropylene plastic composite material
  • Design optimized to combine strenght, protection and weight savings
  • 2-Piece design that includes a CNC-machined (billet aluminum) spring retaining clip
  • Fits existing Elka Suspension shocks (see fitment and compatibility below)
  • Weights only 7.1 oz (204 gr.) for the pair
[/FONT]
[FONT=Arial,Helvetica,sans-serif]BENEFITS:
  • Protection of the shock's shaft from damage caused by flyings debris such as roost, rocks, sand and more that could lead to premature wear and/or oil leaks
  • Enhanced look and functionality to further protect your investment
  • Helps prevent expensive repairs and downtime for racing applications
FITMENT & COMPATIBILITY:
  • 7-1/4" high (185mm), 3-1/4" maximum outside diameter (83mm)
  • Fits existing Elka Suspension shocks (36mm body) in emulsion, piggyback or remote reservoir configurations
  • Compatible with most popular vehicles and aftermarket a-arms applications
[/FONT]
[/FONT]
If I could fit these on my stock shocks, maybe they would think they are Elka's.....:roflblack::roflblack::roflblack:
Elka Shock Protectors
Got a set of the Elka shock protectors installed on my RT today. Installation is pretty easy and they fit perfectly! A nice addition to protect your investment!
Mad Matt
or get works performance shocks ;)
where they mount like the OEM shocks upside down with the exposed shaft up under the spyder ....
sorry Matt for the OT comment ...
but they do look like a nice addition...better then shock boots that cover the shocks. I wonder do they rattle at the top of the protector when hitting bumps as the support is all in the base of the shock protector?
I think they look sharp but would like to see a photo of the whole spyder to see how they look on the bike, please:f_spider:
I just purchased a pair of these. :2thumbs:Installation instructions did not come with:mad:. I can't figure how to install them. Do I need to uninstall the shocks?:dontknow: Or just unload them to make some mounting room at the bottom?
Mad Matt
Hey Matt,
How did you mount them sons-a-bitches?:mad: I don't see how to get them mounted without removing the shocks.:dontknow:
Call Impact Solution 304-863-0025; they install my shock protectors. :doorag:
Hey Matt,
Hello Bootie,
1)To do it without removing the shocks will require you to lift the front of the bike up so that the weight is off of the shocks.
2)Back the preload all the way off( the red ring on top of the spring) so that the springs are loose. Remember to measure or to mark where they are before backing off the preload to make it easier to reset.
3) Once the springs are loose, simly pull out the spring clip ( you will see the groove in the clip where the shaft will slip through) and slide in the new clip with the protector.
4) reset the spring and preload back to its original position
5) Set the front end back down
6) get on the Spyder and ride. :clap:
Hello Bootie,
Ok, Trooper
That looks to make alot of sense.:2thumbs: I'll get them mounted straight away. Weather won't let me ride yet:mad: but when it does...I'm gone:clap:
New?? Elka shock protectors were available when I bought my Elka's three years' ago. I went 'round and 'round with Elka and Pitbull and they didn't think they were at all necessary. I was told the protectors were really for the dirt bike applications where they get dirt and stones thrown at them all day long. Is Elka now changing their tune? Has anyone had a seal failure due to strut damage from debris?
