How and where do these attach and did they come from Elka?![]()
http://www.spyderlovers.com/forums/showthread.php?p=283141&posted=1#post283141I think they look sharp but would like to see a photo of the whole spyder to see how they look on the bike, please:f_spider:
I just purchased a pair of these. :2thumbs:Installation instructions did not come with
Hey Matt,Got a set of the Elka shock protectors installed on my RT today. Installation is pretty easy and they fit perfectly! A nice addition to protect your investment!
Mad Matt
Call Impact Solution 304-863-0025; they install my shock protectors. :doorag:I just purchased a pair of these. :2thumbs:Installation instructions did not come with. I can't figure how to install them. Do I need to uninstall the shocks?:dontknow: Or just unload them to make some mounting room at the bottom?
Hey Matt,
How did you mount them sons-a-bitches?I don't see how to get them mounted without removing the shocks.:dontknow:
Hello Bootie,
1)To do it without removing the shocks will require you to lift the front of the bike up so that the weight is off of the shocks.
2)Back the preload all the way off( the red ring on top of the spring) so that the springs are loose. Remember to measure or to mark where they are before backing off the preload to make it easier to reset.
3) Once the springs are loose, simly pull out the spring clip ( you will see the groove in the clip where the shaft will slip through) and slide in the new clip with the protector.
4) reset the spring and preload back to its original position
5) Set the front end back down
6) get on the Spyder and ride. :clap:
Ok, Trooper
That looks to make alot of sense.:2thumbs: I'll get them mounted straight away. Weather won't let me ride yetbut when it does...I'm gone:clap:
