almosthere
Ok I am at a point with my trailer build that I have a question about the electrical system on my 2015 RT-S SE6. I found out at the dealer that my bike puts out 850 watts running at normal speeds. How much of that does the bike need to operate with stock equipment? I have started adding extras ie: 2 12v ports to plug in our smart phones for gps and play list listening. Also 2 ports to plug in heated riding gear, driver and rider could each pull 14.2 amps if we have set at high on all parts of gear. BTW 850 watts = 68 amps at 12.5 volts. When it comes to my question with my trailer I have built it with electric brakes including a battery on the trailer for emergency brake away switch. I want to set it up to charge while towing, with a combination of an inverter and an ac charger. SOOOO how larger of an inverter can I run form the battery leads from the bike?
