2013 RT-S, SM5. Added LEDs: Spyderpops RTB rear lights with flasher and A arm running lights, Longhorn RT lights on the mirrors, rear trunk lights with 12V push on/off switch.
I left the rear trunk light on by accident for a couple of days, and drained the battery. Per the manual, hooked up the jumper cables with my car off. Turned on the key and had all the normal lights on, including the A arm, rear RTB and the Longhorns on the mirrors. Instrument cluster lighted as normal. Hit the mode switch, pressed starter button, got a couple of loud clicks, no start, and the cluster went dark as well as the A arm lights. OEM fog lights and both front and rear turn signals stayed on as normal but wont blink. Tried leaving the cables connected for a few minutes with the key off but no change. Bike is in neutral with paeking brake on. OEM battery I thin, bike was purchased used.
Sounds like I may have fried a fuse or two, but now that its dark I really don't have a spot to continue working. Any suggestions as to where to start in the morning?
Bob
Bob
