Sarge707
"To bed in sintered pads, drive the vehicle carefully allowing extra braking distance for the first 300 miles. Please be aware that brake performance during the bed in period may be significantly less than you have been accustomed to. What you are looking for is to see a 90%+ surface area contact between the pad and the disc or rotor before optimum braking will be achieved.
Once your pads are 90% surface area bedded after the 300-400 miles, on a safe road, use the brakes 10 times in succession stopping your motorcycle from 60mph to 20mph to get the brakes deliberately hot. This is particularly important with the organic versions (aramid fibre types, carbon based pad types and semi-metallic pad types). After this process, the pads should settle down and normal riding and brake performance can be safely achieved."
ABOVE from EBC website!!
Installed the Rotors and Pads and followed the above today for 80 miles- Couple hundred miles to go. Relaxed riding, downshifting the sm6 , and Generally Very easy on the pedal. The 2015 are Fully sintered and when I got home the Rotors were cool and
started to show break in But Just Gotta be patient.
Anyone else have the experience with the 2013-2019 product??? Is there a different way for the Bremo Fully sintered Pads and Rotors?? Thanks ( Bajarons service and Prices can't be beat)
