Fat Baxter
I noticed last week that I'd lost one. New one due in at the dealer any day now. Will silicone both.
I was concerned because my 2012 RT A&C is missing both front wheel caps and the axle nuts and bearings are exposed. That is until I looked at a parts diagram and discovered that there is no such part on a 2012. So I wonder if those caps are truly necessary.
UPDATE: on further research I determined that the inner wheel caps were not added until the 2013 model (i.e. 2010-2012 did not have them). I might assume the same part would fit on a pre-2013. Does anyone have an opinion whether I should add them on my 2012? It still has low miles (~7000) and so far the front wheel assemblies are very clean and almost new-looking.
this is what I am looking for ------- I saw it in original packaging on line ... this one is listed as a " front wheel hub cover " ------ I had miss stated it bolts on the fender area , it looks like it bolts onto the hub bolt section ... will double check into this idea !![]()
I found these on ebay
[FONT="]
- [TABLE="class: img, width: 74"]
[TR]
[TD="class: tdThumb"]![]()
[/TD]
[/TR]
[/TABLE]
[TR]
[/TD]
[/TR]
[/TABLE]
[/FONT]
[FONT="][h=1]Can Am Spyder Front Wheel Hub Covers[/h][/FONT]
http://www.ebay.com/itm/Can-Am-Spyd...ash=item1c906652d8:g:GfIAAOSwlEdZqcax&vxp=mtr
[FONT="]
[TR]
[/TD]
[/TR]
[/TABLE]
[TR]
[/TD]
[/TR]
[/TABLE]
[/FONT]
That Ebay post says it came off a GS model. I wonder if it will fit an RT???
I looked at the mount situation , I would use only the top 2 hole pattern looks like the lower ones bolt too the actual hub assembly , I do not wish to mess with the alignment area of the tire , but I would think the upper holes would do just fine ... I saw these in the packaging somewhere in the world of internet fun ...
looked at mine this morning after seeing this post both are gone, how long can you ride with them missing?
The part number is 705401100, wheel cap
