tconaagt
If you have to do some "bush body shop" repairs & you have to readjust drive belt tension without the use of a belt tension meter,is there a way to "ball park" the tension?I know it shouldn't be "banjo string" tight or hanging loose.(somewhere in between).Could you use a string straighy edge or?Would the best case scenario be better loose or tight?
thanks for advise
thanks for advise
