DPS LIGHT
neelbert
When I parked my 2010 RTa/cSE-5 6 weeks ago no lights or codes Iv'e been pushing it around the shop from place to place I started it this morning and got check DPS and a red eng light on the dash any Ideas I can't remember how to make it show the code with the mode button Thanks Neel
neelbert,
Could this be a case of the battery being a bit low from the last six weeks of inactivity?
Can you throw it on a charger and see if that helps?
Good Luck! :thumbup:
Bob's suggestion about charging the battery is a good one. :2thumbs: I would recommend trying that first.
Two codes PD551 and PD552 where do I find what they mead THANKS NEEL
P0551 = Torque sensor open
P0552 = Torque sensor short to ground
The remedy for either is to replace the DPS...but I would charge the battery first and see if they go away. A low battery can cause all kinds of faults.
I've got a battery tender on It
Well then, time will tell...
