Does Eco mode really make a difference?
vito1943
Being relatively new to my Spyder bought new last summer, I thought it odd that I need to press the Eco Mode button to start the bike, but I've gotten used to it. For the most part I leave it in Eco Mode and I like seeing the arrow indicating when to upshift for best mpg, even if I ignore it much of the time. But I wonder how much difference it really makes to ride in Eco Mode versus not using this feature. I also own a Mini Cooper S which has a "Green mode" button, which wants you to upshift noticeably sooner than in regular mode, but the actual mpg doesn't seem to change at all, so I wondered if the same was true for the Spyder.
I didn't noticed any difference in fuel mileage on my RT when I was comparing the modes. I no longer use eco mode except maybe in a heavy rain where the softer power delivery may help with traction.
Yes, ECO mode will make a small difference if you use it. You must ride conservatively though. If you ride hard using high RPMs and make quick takeoffs then you won't likely see any difference. Don't be looking at the green arrow too much. It can be a distraction. Learn the feel and sound of your machine and shift according to the feel of the engine and the sound it gives you. It just takes practice.
I use eco mode for two occasions: 1.) Rain/wet roads and 2.) On interstate for long distances. Makes a slight difference if you use the shift points. Always in the rain though. ..
When it first came out, (2014) I believe, I tried it on two tanks of gas. Faithfully shifted when it said to. I figured ECO saved me about 1 mpg. I don't use it on any of the subsequent machines. I shift by sound and feel, not when a computer says I can. :bowdown:
This graph shows what ECO Mode does. It flattens the acceleration curve. IMO it's an unnecessary PITA.
Useless
Haven't used it in years----- Seldom rains in the high desert..........
Lew L.
I never use eco mode. It is only turned in very occasionally and even then, it’s by accident. Personally, I don’t need a computer to tell me when to take it easy. I ALWAYS ride according to CONDITIONS (whether it’s road, weather, highway). That’s the way I learned to drive/ride 70 years ago, and still use it.
Our local Can-Am guy told us that ECO is helpful if you combine it with your cruise control on a long run at interstate speeds.
Haven't tried it yet myself. Your mileage may vary, of course.
Don't forget that selecting ECO Mode also desensitises the throttle input (see the graph JayBros posted above ;) ) so IF you can manage to ryde smoothly & gently, always short shifting & changing gears iaw the green arrows, there's no reason you shouldn't get slightly better gas milage.... but as ARtraveler & others have mentioned, there really isn't all that much in it! :dontknow: .
Besides, it's not actually the 'ECO' button you push before starting - as everyone who's owned an earlier Spyder knows, it's the MODE button that you hafta press before starting :thumbup: . It was only after some marketing guru had the bright idea to add a pretty useless gimmick in order to appease the 'rampant anti-gas use crowd' and they added toggling the ECO function to all the other things that the MODE button does that it scored that extra label so those not in the know can become confused - but it's still the MODE button for everything else! :ohyea:
Altho if you still think that selecting ECO mode is gonna save you heaps of gas, I do have this historic bridge that you might be interested in buying at a heavily discounted price... :roflblack:
IMO, your local Can-Am guy pegs the BS meter. Since the ECO mode flattens the acceleration curve, at interstate speeds I want full power acceleration -- just in case. Traveling at interstate speeds your fuel consumption is dependent on engine rpm, atmospheric factors plus terrain and road surface conditions, whether ECO mode is used or not. If you use cruise control, it and the ECM are going to keep the engine in the rpm range necessary to maintain the speed you set.
Other than the suggestion of shift points I can detect NO difference between ECO and normal mode. On my Terrain the difference is obvious as with many other vehicles.
That could hold true if you are on a freeway with a lot of elevation changes.
Last week I travelled 2k km and I decided to use eco mode cause the rain and cause it was a long travel. So I obtained 5.5 l/100 km un roads at 80/90 km and 5.9 in motorwsys at 120 with long periods of cruiser speed control. I can't say if the quantity is for low speed, eco mode or control speed cruiser but normally the medium consumtion in 6.5/7 l / 100 km.
Eco mode
:agree: Eco Mode is not what you feel.
I have tried it but no real gasoline savings.
I don't use it anymore. .....:thumbup:
My guess is Eco mode is primarily there so Can-am can meet, or appear to meet, the regulatory requirements of certain countries or states. It gives a 'green credential' that can be used to deflect questions on environmental impact.
Its also something that with modern electronically controlled engines is low cost to include (just a button and a different profile), yet has 'value add' for marketing purposes.
The majority of riders will probably try it out and then never use it again - though interesting the idea of using it in the rain as I suspect it would be useful on gravel as well so will keep it in mind.
I have kind of a related question. I ride with some other Spyder owners that will drive miles out of their way to make sure they are using 90 octane gas.. I personally have tried both 90 and 87 and do not see one MPG difference. wonder what others think on this?
BIG F
Stop and think though. If you have ECO mode and cruise control on and on and you come to a long interstate grade, with the acceleration curve flattened it is going to take longer for the Spyder to get back to the speed you set on the CC and you could very easily wind up with some moron on a cell phone running up your backside. The steeper the grade the longer it will take the Spyder to get back up to the CC speed.
BIG F
On tours out west of NE I have had to use 87 and noticed absolutely no difference in performance or mpg. Matter of fact, this past Sat. I took a different route home from a routine ride and had refuel with 87 (poor planning on my part). Since I track every tank full I will get a local confirmation on non-confirmation of of my touring experience with 87. I think BlueKnight911 uses 87 all the time and has noticed no degradation of performance or mileage.
