I had to completely remove the air trunking across the front of the engine and the 'expansion air-box' thingie (highly technical term that one!!? :dontknow: ) on the LHS before I could remove the machine screws holding the ECU to the frame - IIRC the screws were about 40mm long and the gap remaining between the trunking/exp box & the ECU was only 20mm at best..... so that trunking & air box hadta come completely out. The ECU was almost certainly mounted onto the frame
BEFORE the engine & air intake assy was inserted!! And to get the air intake/trunking out, because of how the whole lot is connected, the top of the air cleaner cover & the flexible snout that connects the air cleaner to the trunking & air box hadta come off too!! All that entailed either completely removing the engine & fuel tank, etc; or removing the headlights, undoing the dash/cowling assy behind it, and then lifting & raising the whole head/dash assy from the headlight brackets on up out of the way..... :yikes:
I suspect that the 2013 ECU's are a 'little' harder than most to get out (the 2012's aren't really all
that much easier, but from 2014 on, they're basically a PoP!
) because of the frame, mounting positions, & assembly process changes that were made to cater for the 1330 Triple engine size/configuration changes before BRP realised that engine wasn't going to be ready in time so they just jammed the V-Twin engine assy, complete with it's air intake trunking etc back in any old how..... but only once all the loom, ECU & everything else ancillary to that had already been fitted up to the frame..... making some things (like the ECU!) damned near impossible to access &/or remove/replace in the process!! :gaah:
At the time, I swore I'd never try removing a 2013 Spyder ECU again, altho once my hands had largely recovered from the resulting surgery (No, I'm not joking!! I
DID say 'resulting surgery'!! :shocked: ) I've done a couple of others using the demo saw method. (What can I say?! I
am a bit of a tenacious bugga & obviously also into pain....
) It's just a whole lot quicker, cleaner, and far less traumatic in the long run to use a demo saw, as well as being just a little cathartic!!
hyea: Bit messy tho, lotsa black 'placcy dust' left to clean up (but shop air works well!) and you hafta be very careful
NOT to touch anything that's not gonna be thrown away!! :shocked:
Good Luck - and be very careful where you put your hands in there - whichever removal approach you decide to use! :thumbup:
