Does a 2023 F3 Ltd have an air valve for ACS under the seat?
Elwood58
On my old RT-S there was a Schraeder Valve under the seat, even though it had the automatic air suspension. On my 2023 F3, there does not seem to be a Schraeder valve. Am I missing something?
You're not missing anything - the newer up-market models don't have the underseat valves. :thumbup:
I think it was about 2022 that they went fully automatic, dispensing with the valve under the seat completely, but still having all the rest of the Automatic Suspension/Ride Height setting system. I'm sure someone will chime in with the correct year if I'm wrong about that. :ohyea:
The 'Soft/Hard' dash switch thing was always a bit of a con to suck in the un-knowing tho... ::banghead: If you had/have the Auto System on those earlier up-spec models rather than the manually set pressure on the base models or an owner modified full manual system, it didn't really matter what you set the level or air-bag pressure at, either by using the dash 'Soft/Hard' switch or by adding air manually via the under-seat valve; cos as soon as you started riding, the system would revert to whatever pressure it took to maintain the preset ride height, adding or bleeding off air to suit!! :rolleyes:
And AFAIK, the only way to change that pre-set ride height was thru the appropriate BUDS setting! :dontknow:
Your 2023 F3 Ltd does not have the Schraeder valve. It has Sachs Shocks with a Self-leveling Air Pre-load Adjustment System. You will hear a sound/and feel the self-leveling system doing its thing as you load it up &/or ride, it is all automatic. So No, you are not missing anything.
I have a 2023 F3 Ltd Special Series and it too has the same Sachs Shocks and the Self-leveling Air Pre-load Adjustment System.
Deanna
