It is a rather long and convoluted story that has been adapted and changed multiple times.
I started by installing the F3 idler on my 2017 F3S Daytona. I got to thinking about it and wondered if it could be adapted to our 2014 RT. I did some tests and finally came up with a prototype and gave it a try using the BRP kit. I couldn't believe the lack of vibration on the RT. In fact, having both the F3 and RT I could tell that the F3 idler actually worked better on the RT than the F3. I was concerned about clearance of the gas tank and the tensioner (which was the reason BRP did not would not use it on the RT. By removing all the air out of the airbag, and with the tupperwear off, I simulated a complete rear suspension failure and with the tire setting on the inner fender, we still had 3/4" of play from the pulley to the tank.
I then started to work on a vibration damper that would be more durable that the idler kit for the F3. We have finally got it dialed in with a total of 5 different kits and the original adaptor kit. This works for any aspect that someone wishes to do. Most everyone has this link already, but I will post it for those just getting up to speed.
In everything we do at Roadster renovations, we have tried to use the best quality items available so that everything we make makes our bykes perform better and work better than original.
Here's the link:
http://dochumphreys.wixsite.com/roadster/ultimate-vibration-damper-products
